If I want to employ 3g bonding without two devices but only one MAX OTG (4 3g cards with 3mg DL each), can I connect the MAX OTG to a service that will assist it in bonding? If so, how much? …and how do I configure it on the MAX OTG?
There is currently no other service available that will bond the connections, so you would need to use a second SpeedFusion enabled Peplink/Pepwave device.
Understood, thanks for the reply. We will continue to try to get our pair of MAXOTG’s to connect and enable bonding.
