hello I have pl380 in center connect direct sflayer2 tonhd4 and br1
When I config the vlans between the center and edge the management to hd4 fail
But it’s works and I rich to of behaind the hd4 or br1 whan I disconnect the wan I got the management this happens when sf up
How can I fix the management to devices ?
The topological
Firewall vlans trunt to—-pl380 vlans make layer2vpn ——hd vlan —-pc
Firewall 10.0.0.100/24 net lan customer
Connect to trunk vlans like 10.10.44.254 vlan 68
10.10.43.254 vlan 69
To pl 380 vlans trunk vlan 68 10.10.44.245
To hd4 10.10.44.1 pc 10.10.44.100
Pl Vlan 69 10.10.43.245 to br1 10.10.43.1
Pc 10.10.43.100
When sf up I lost the management of hd4 10.10.44.1 and 10.10.43.1
But I ping the pc and it works when I disconnect the wan without speedfusion I see the management this the prob how
Can fix that ? The version peplink ver 6
The management IP address is overridden when the bridge is connected and you define this in the Layer 2 PepVPN bridging profile. The 380 should be set to “Do not override” and the HD4 can be configured as “Static” or “By DHCP” in which the DHCP address would be provided by the 380’s LAN DHCP server.
