Thanks for your feedback. FusionHub does not support LAN port belongs to different organization if Layer3 SpeedFusion is enabled in non-VRF domain. We will add this to feature request.
To fit your deployment:
Able to specify the management VLAN for LAN port (that will also be used in Layer3 SpeedFusion)
Layer 2 SpeedFusion is on “trunk” except the management VLAN is filtered.
In this scenario there is no Layer3 tunnel. The hub is used to distribute Layer2 over multiple sites on multiple customers. So traffic must be isolated customer per customer. That’s where VRF could have been useful but in the end, all traffic is mixed. Even with different VRF.
On point 2, do you mean we could assign outgoing VLANs to Layer 2 tunnels per VRF? And assign one outgoing VLAN per customer ( but multiple sites in one VLAN)
We want to avoid that shared Layer2 hubs mix the traffic of all customers.
@Kenny I have a situation I’m working on now with hub and spoke, each spoke has 1 layer 3 subnet and three layer 2 vlans. These are all connected together via the hub using sub-tunnels.
The current hub (a balance) has the same vlans configured, so you can connect to equipment on a vlan in one location and the same equipment in the other locations are accessible because they are in that vlan too - the hub bridging all VLANs.
Wish I could add multiple VLANs on the LAN of the fusionhub to make that work. I am currently juggling fusionhubs with clown shoes on building a work around and I may well end up with egg on my face before the morning comes
Hi @Jonathan_Pitts, as the nature of FusionHub is very different from a Balance or MAX, this “Override IP Address” option is not available on FusionHub.
So here is how Layer 2 PepVPN works on FusionHub:
FusionHub with both WAN and LAN: connected Layer 2 PepVPN peers will be able to communicate with each other as well as LAN interface, “Remote Network Isolation” is available only for this scenario.
FusionHub with WAN only: connected Layer 2 PepVPN peers will be able to communicate with each other only, local network interface (i.e. WAN) is not bridged together.
FusionHub using VRF: This should work just like the “WAN only” scenario, even the FusionHub has both WAN and LAN interfaces, but you can utilized different VRF domain to isolate different Layer 2 PepVPN peers.
NOTE: VLAN Whitelist filtering should work in all 3 scenarios.
Can it operate in static,DHCP or none options then?
I assume it would never be the source of the DHCP based on what you described, but it seems like it should have the other options.
One of my questions is If I connect two layer two device and the fusionhub which side will be the DHCP server, when doing this with max/balance very easy to know, not so much with fusionhub.
The positioning of FusionHub is a Hub, it helps to connect different devices together, we are not expecting the LAN of FusionHub to be overridden by an external device, can you describe more about the scenario that require overriding FusionHub’s LAN?
I am trying to setup a Balance 310x for L2 PepVPN to Fusion Hub in AWS. Ultimate goal would be for my local network to appear as if it was in my AWS VPC. I am getting lost in AWS VPC side of things any links to articles about this configuration would be greatly appreciated. I am a novice when it comes to IT thank you for the guidance in advanced.
