It would be great to have an option for Balance 210/310, which allows to check traffic statistic for each LAN IP for a certain period. Now, it is possible to check only overall WAN statistics.
Are you referring to “Client Bandwidth Report” ? The reports is available in hourly, daily and monthly basics. For more information, please refer to the attached screenshot.
Thank You
Thanks for early reply!
Is it option to check overall WAN uplink status (hr:mm or %) for a month?
Many thanks. And what is about uptime?
Is it overall info or since last reboot?
It was based on the WAN uptime. It will be reset if WAN was down or router reboot being rebooted.
