Does Peplink Balance 710 support LACP (802.3ad) NIC bonding LAN Port?
Hello cvnd,
LACP (802.3ad) NIC Bonding is supported on the LAN on the Balance 710.
Hi Zach,
Is there a link on how to do this? I was just thinking about doing this and connecting it to an SD-Switch.
Best,
Niko
Balance LACP (supported models) configuration is very straight forward, you just need to tick which “LAN interface” or “WAN as LAN” as LACP ports.
Thanks! This is great - I’ll give it a try!
