I managed to capture error logging from the macOS ‘raccoon’ process trying to set up a VPN with the Peplink router.
In this log, A.A.A.A is my remote IP address, and B.B.B.B is the address of my Peplink.
IPSec Phase 2 established (Initiated by me).
IPsec-SA established (add): satype=3 spi=0xc477265c mode=1
IPsec-SA established (add): ESP/Transport A.A.A.A[500]->B.B.B.B[500] spi=3296142940(0xc477265c)
>>>>> phase change status = Phase 2 established
vpn control writing 20 bytes
Dropping com.apple.security.LegacyAPICounts as it isn't used in any transform (not in the config or budgeted?)
DatabaseSession::Close
DbClose of handle 140543612981885
0x7fd2dc209370 free /Library/Keychains/System.keychain buffer 0x7fd2e0008000
Thread registered with com.apple.SecurityServer
0x7fd2dc208d00 detach module 0x7fd2dc208990(AppleDL)
0x7fd2dc208990 module AppleDL(Apple built-in DL) final unload
0x7fd2dc70f490 detach module 0x7fd2dc7334a0(AppleCSPDL)
0x7fd2dc70be40 detach module 0x7fd2dc7334a0(AppleCSPDL)
0x7fd2dc7334a0 module AppleCSPDL(Apple built-in CSPDL) final unload
caught rtm:2, need update interface address list
configuring default isakmp port.
26 addrs are configured successfully
vpn_control socket closed by peer.
received disconnect all command.
IPSec disconnecting from server B.B.B.B
in ike_session_purgephXbydstaddrwop... purging Phase 2 structures
New Phase 2
state changed to: IKEv1 info
Compute IV for Phase 2
hash(sha2_512)
encryption(aes)
hmac(hmac_sha2_512)
Begin encryption.
encryption(aes)
pad length = 12
About to encrypt 96 bytes
encryption(aes)
Encrypted.
124 bytes from A.A.A.A[500] to B.B.B.B[500]
sockname A.A.A.A[500]
send packet from A.A.A.A[500]
send packet to B.B.B.B[500]
1 times of 124 bytes message will be sent to B.B.B.B[500]
sendto Information delete.
IV freed
Phase 2 sa expired A.A.A.A-B.B.B.B
state changed to: Phase 2 expired
in ike_session_purgephXbydstaddrwop... purging Phase 1 and related Phase 2 structures
IPsec-SA needs to be purged: ESP A.A.A.A[500]->B.B.B.B[500] spi=167772160(0xa000000)
New Phase 2
hash(sha2_512)
encryption(aes)
hmac(hmac_sha2_512)
Begin encryption.
encryption(aes)
pad length = 16
About to encrypt 112 bytes
encryption(aes)
Encrypted.
140 bytes from A.A.A.A[500] to B.B.B.B[500]
1 times of 140 bytes message will be sent to B.B.B.B[500]
IV freed
ISAKMP-SA expired A.A.A.A[500]-B.B.B.B[500] spi:cf535c2e3e206ac1:ca6782ebd853f95d
state changed to: Phase 1 expired
no ph1bind replacement found. NULL ph1.
vpncontrol_close_comm.
