[Known Issue] [8.6.0] GPS Location Not Displayed in IC2
Ref.: #37160
Details:
In firmware 8.6.0 GA, we discovered that a few routers with the GPS function are unable to display the location information in InControl 2. However, the router’s local Web Admin - Dashboard does see the map and has the GPX file, it is similar to the symptom described in this post.
This is found on the router models with certain cellular modules (LTE or LTE Advanced variants), that are running firmware 8.6.0 GA only. Other firmware versions are not affected.
We have prepared a special firmware (8.6.0s019) to mitigate the issue. The fix will be included in the next GA release, 8.6.1 (currently in Beta).
Affected firmware version:
8.6.0 GA
Affected models:
MAX Transit Pro Duo
Balance 20X
UBR Plus
MAX BR series (certain models as shown below)
Fixed in firmware version:
8.6.0s019
Here are the direct download links:
Download Link Product
Download MAX Transit Duo Pro Series
Download Balance 20X
UBR Plus
Download BR2 LTE
BR2 Micro
MAX BR1 Mini Series
