[Known Issue] [8.5.3] USB WAN Config Missing After Reboot
Ref.: #35032 (#35982)
Details:
We have received several reports from users experiencing issues with their devices’ USB WAN, which is no longer able to connect after updating to firmware version 8.5.3 GA.
Upon investigation and verification using a lab device, we noticed that the USB WAN configuration is restored after upgrading to firmware version 8.5.3 GA.
In addition, any changes made to the USB WAN after upgrading to version 8.5.3 GA will no longer persist after a reboot.
We have prepared a special firmware (8.5.3s042) to mitigate the issue. The fix will be included in the next GA release.
Affected firmware version:
8.5.3 GA
Affected models:
All device models that support USB WAN
Fixed in firmware version:
8.5.3s042
Download Link Product Hardware Revision
Download B One Series HW1/HW1-2
MAX BR1 Pro CAT-20 HW7
MAX BR1 Pro 5G HW1
MAX BR2 Pro HW4
MAX Dome Pro LR HW1
MAX HD1 Dome Pro HW1-2
MAX Transit Duo Pro HW1
Download Balance 2500 EC HW1
Balance 1350 EC HW1
Balance 310 5G HW1-2
Balance 310 Fiber 5G HW1-2
Balance 310X HW1-4
Balance 380X HW1
Balance 580X HW1
Balance Two HW1
EPX HW1
MAX HD2 MBX HW1-4
MAX HD4 MBX HW1-4
MAX MBX Mini HW1
PDX HW1-2
SDX HW1-3
SDX Pro HW1-2
Download Balance 20X HW1-3
MAX BR1 IP55 HW4
UBR Plus HW1
Download Balance 210 HW4-5
Balance 30 LTE HW3
Balance 30 Pro HW1
Balance 310 HW4
Balance One HW1-3
Balance One Core HW1
MAX 700 HW3-4
MAX BR1 ENT HW1-2
MAX HD1 Dome HW1
MAX HD2 HW5-6
MAX HD2 Dome HW1
MAX HD2 IP67 HW2-5
MAX HD2 Mini HW1-4
MAX HD2 with MediaFast HW1-4
MAX HD4 HW1-5
MAX HD4 IP67 HW1
MAX HD4 with MediaFast HW1-4
MAX Transit HW1-3
MAX Transit 5G HW2-3
MAX Transit Core HW1
MAX Transit Duo HW1-3
MAX Transit Duo Pro E HW1
MediaFast 200 HW1,3
SpeedFusion Engine Cam HW1
Download Balance 1350 HW2
Balance 2500 HW1
Balance 305 HW2
Balance 380 HW6
Balance 580 HW2-3
Balance 710 HW3
MediaFast 500 HW1-2
MediaFast 750 HW1
Download MAX BR1 Mini HW3
MAX BR1 Mini 5G HW1
MAX BR1 Mini Core HW3
MAX BR1 Mini M2M HW1
MAX BR2 LTE HW4
MAX BR2 Micro HW1
Workaround:
Optionally, you can downgrade to the previous firmware version, eg. 8.5.2 or earlier.
Hey @WeiMing , I updated to this firmware on a BR2 Pro 5G that I have and was having issues with the 5G Max Adapter (the dongle). Now, it won’t connect to the device reliably, tells me “no peplink esim subscription” even though peplink eSIM is disabled for that interface, and also shows “no physical status” often. In short, it went from not working to really not working :slight_smile: Any advice?
Hi @ChristopherSpitler, we tried to reproduce this but failed. I am able to connect to SIM A without issue even performed a reboot on the router or the MAX adapter. Could you help open a ticket for us to further check and support you on this?
Ticket 25100812 filed.
Are these “s” releases cumulative? Or forks / hot fixes? In other words, does this include the beta iPhone USB tethering support? Thanks!
Hello Everyone,
We have been working with the Peplink team, and there is another version (excluding the iPhone tethering) that we are testing; the results are looking promising. There should be an update from the Peplink team posted on this soon.
Have a good week,
Marcus :slight_smile:
In general, special firmware versions are not cumulative unless stated otherwise in the description provided above. The special firmware will mainly targeted for those specially using the feature which required a fix before it been cumulative in the next GA version.
For cases that are more complex and may involve multiple issues requiring a combination of fixes, please create a support ticket so that our team can review and provide further assistance.
Does this USB-WAN issue affect wan2 on the B One 5g?
The new dedicated firmware 8.5.3 for Balance One Core, 8.5.3s042-build5789 deletes the USB WAN feature completely. Looking forward to a fix for this even though support for Balance One Core goes end of life after 8.5.3. For me this feature gets used all the time.
@chris_heard this is strange… :thinking:
I have a quick setup with our lab unit (Balance One Core) with the special firmware, 8.5.3s042, I have no issue connecting a USB-Ethernet adapter, although it’s name as “Mobile Internet”…
Physical connectivity
Probably, you can submit a ticket for our team to take a closer look at the device?
Please include the device S/N and quote this forum in the ticket so that the team member who takes on the case is aware of the background.
