[Known Issue] [8.5.3] Firewall or Outbound Policies with Grouped Networks and Domain Rules Not Working
Ref.: #35401 (#35979)
Details:
After upgrading to firmware version 8.5.3, the customer reported that the Firewall and Outbound Policy using a combination of Grouped Networks together with a domain-based criterion will no longer take effect.
Example #1 - Outbound Policy: (Source = Grouped Networks | Destination = Domain Name)
Example #2 - Firewall Policy: (Source = Grouped Networks | Destination = Domain Name)
Example #3 - Grouped Networks with Domain Name classification (which will be applied to Outbound Policy or Firewall Policy)
The above are example policies that no longer take effect after upgrading to version 8.5.3. As long as the configuration involves the use of Grouped Networks together with a domain-based criterion, it will be affected by this issue.
We have prepared a special firmware (8.5.3s093) to mitigate the issue. The fix will be included in the next GA release.
Affected firmware version:
8.5.3 GA
Affected models:
All models, excluded FusionHub.
Fixed in firmware version:
8.5.3s093
Download Link Product Hardware Revision
Download B One Series HW1/HW1-2
MAX BR1 Pro CAT-20 HW7
MAX BR1 Pro 5G HW1
MAX BR2 Pro HW4
MAX Dome Pro LR HW1
MAX HD1 Dome Pro HW1-2
MAX Transit Duo Pro HW1
Download Balance 5000 EC HW1
Balance 2500 EC HW1
Balance 1350 EC HW1
Balance 310 5G HW1-2
Balance 310 Fiber 5G HW1-2
Balance 310X HW1-4
Balance 380X HW1
Balance 580X HW1
Balance Two HW1
EPX HW1
MAX HD2 MBX HW1-4
MAX HD4 MBX HW1-4
MAX MBX Mini HW1
PDX HW1-2
SDX HW1-3
SDX Pro HW1-2
Download Balance 20X HW1-3
MAX BR1 IP55 HW4
UBR Plus HW1
Download Balance 210 HW4-5
Balance 30 LTE HW3
Balance 30 Pro HW1
Balance 310 HW4
Balance One HW1-3
Balance One Core HW1
MAX 700 HW3-4
MAX BR1 ENT HW1-2
MAX HD1 Dome HW1
MAX HD2 HW5-6
MAX HD2 Dome HW1
MAX HD2 IP67 HW2-5
MAX HD2 Mini HW1-4
MAX HD2 with MediaFast HW1-4
MAX HD4 HW1-5
MAX HD4 IP67 HW1
MAX HD4 with MediaFast HW1-4
MAX Transit HW1-3
MAX Transit 5G HW2-3
MAX Transit Core HW1
MAX Transit Duo HW1-3
MAX Transit Duo Pro E HW1
MediaFast 200 HW1,3
SpeedFusion Engine Cam HW1
Download Balance 1350 HW2
Balance 2500 HW1
Balance 305 HW2
Balance 380 HW6
Balance 580 HW2-3
Balance 710 HW3
MediaFast 500 HW1-2
MediaFast 750 HW1
Download MAX BR1 Mini HW3
MAX BR1 Mini 5G HW1-3
MAX BR1 Mini Core HW3
MAX BR1 Mini M2M HW1
MAX BR2 LTE HW4
MAX BR2 Micro HW1
Workaround:
Optionally, you can downgrade to the previous firmware version, eg. 8.5.2 or earlier.
if using local try using in control and check wan names on wan in in control but also set the default outbound profile to use your first wan then second wan do not include speed fusion this should;d help I had this issue when the data commands where not manually set with peplink as well for default traffic
