Multi-Band Support Compatible with LTE, 5G, and GPS, ensuring optimal performance regardless of location or network type.
Marine-Grade Durability Built to withstand harsh weather conditions, making it perfect for maritime adventures or challenging outdoor environments.
High-Gain Efficiency Boosts signal strength to maximize performance, reducing latency and dropouts, even in low-signal areas.
Plug-and-Play Integration Works seamlessly with Peplink routers and devices for a hassle-free setup.
Compact Design Sleek and unobtrusive, the Antenna Max integrates into any setup without compromising aesthetics.
In the ocean of high-speed, uninterrupted connectivity, Peplink Antenna Max stands out as a game-changer. Designed for both rugged environments and seamless performance, this innovative antenna lineup ensures your devices are always connected, whether you’re at sea, on the road, or managing operations in remote areas.
It is awesome that the BR1 Pro 5G fits inside the Antenna Max! But it doesn’t seem that Peplink offers the PoE splitter they show in the Antenna Max datasheet? I need that splitter to convert from PoE to their 4-pin power input on the BR1 but can’t find it anywhere. Instead I’m looking at a splitter off Amazon and a conversion cable from barrel type to the 4-pin
