Just my two cents worth
After using Pepwave products over the years, I have found them to get wonky over time. I’m guessing because I power cycle them daily in my mobile environment. 100% of the time, the issues were 100% fixed by selecting the reset default settings option in the device settings menu. Just thought I would share.
Can you elaborate more of the problem you faced?
Thank you for asking. It may still be an issue with other devices connected to the router. I will post again if I feel more comfortable pointing a finger.
Ok. I still suspect. Just generalized performance. I may sit there buffering a video after power cycling one or more times if I don’t restore default settings in the menu. Restoring default settings fixes it every time. I suspect not having a software shutdown routine scrambles it’s marbles a little bit. I mostly use it for cellular or WiFi as wan but I don’t think that’s relevant. I’m fine with resetting settings after a power cycle, but I just wanted to share.
