I am having issues using InTouch correctly with a Teradek video encoder connected to my Peplink MAX Transit Duo Pro. The end goal is to access the video encoder’s management page on port 80 of its local IP address.
I am able to set up the InTouch link, and even access the page. It goes so far as the management page opening and showing the Teradek logo, but nothing else loads. I’ve tried every iteration of compatibility modes with no success.
I don’t see any errors in console or the network tab in the inspector, but the page just seems to hang and never load completely.
I’ve had similar issues with Cradle point routers and their version of Intouch, but it has worked perfectly with GL.iNet’s Astrorelay (yet another tunneling tool) so I know it’s doable, but I’m not sure what it is about how this management page is coded that it causes issues with both Peplink and Cradlepoint.
I’ve since gone down the rabbit hole of trying to set up Tailscale, but its a huge learning curve for my level of knowledge. I’ve set up tailscale on PC/linux and that was fairly easy, but im a bit lost when it comes to the Peplink. It seems I would have to use Tailscale’s docker, which I’ve managed to pull onto the Transit, but a bit lost from there on.
I tried setting up Remote User Access with OpenVPN, but that didn’t work either, my connection would just time out. I assume this is because my OpenVPN client was trying to connect to the IP given by the carrier, which is behind cgNAT?
I would love to get InTouch working as it would be the most straightforward workflow, but any suggestions are welcome!
