I have set up a test PepVPN tunnel between two BR1’s
I have swapped the WAN’s to Lans and plugged 3 devices into each (Now) Lan port.
I noticed it’s very spotty and difficult to access web management interface on the devices, or even ping them. Though I can ping the cell modem itself when the PepVPN tunnel is instantiated.
Is there something I’m missing in order to make this work well?
I know you are using OSPF between them during PepVPN Tunnel, is there something I need to do on my local computer to access consistently the devices across the tunnel?
