Sofar I have used only one profile to connect to my WAN WiFi and had no problems.
The last few days I have been travelling and connected to multiple Access Points. For every AP I created a profile.
Back home I selected my original and oldest profile, the Surf OTG connected to the AP, configured my 3G as backup link and everything seemed OK.
Until I looked in Basic Settings –> WiFi WAN Settings –> Profile select.
The profile which is listed there is NOT the profile the OTG is connected to, but is the LAST profile I created when travelling and therefor not even close.
I selected my home profile, saved the new settings and checked the Dashboard to see that indeed my home profile was active.
Went back to: Basic Settings –> WiFi WAN Settings –> Profile select and… again that wrong profile was listed.
So I took a drastic step and deleted that last profile, went back into settings, selected and saved my home profile and logged out of the web interface.
When I logged back in, I found the one-but-last profile I created and again NOT my home profile.
IN SHORT: Whatever I do it seems that always the last created profile shows in the settings. Is this “as designed” or am I right that this is not what it is supposed to do? (NOTE: The OTG keeps on functioning well)
