I am having a problem in which I cannot Resolve. I have a Public IP /29 Block assigned to WAN 1 of a Peplink 1350, I would like to provide 172.16.1.175 with a Public IP from the /29 Block, when I do a NAT Mapping this works Perfectly however now my Whole Server is Exposed to the Public Internet, if I try doing a Inbound Access Rule and Select the Interface and IP address I would like with the Ports needed this only works for the Inbound Side and not the Outbound Side. If I also Create an Outbound Firewall Rule the Server now takes the IP of the Interface and not one of the IP’s in the /29 Public Block.
I have tried both Inbound Policy and Outbound Policies, the ONLY way this works is if I NAT Map, however if I NAT Map then it defeats the Point of Having a Firewall as now my server is Accessible on the Public Internet
Also for Clarification this is for an IP SIP Trunk which is using IP Auth via a Specific Public IP address, again NAT Mapping works perfectly however with NAT mapping my whole Server is Exposed.
I tried filing a Ticket with [email protected] but they are Hopeless
