Bug: When using Router Utility ver 1.5.1 we note some curious behavior (OK, let’s call it a minor bug): When looking at the status of a USB 4G modem in two Balance One routers we observe the signal strength shown in “bars.” However in each case the signal strength is reported as 0 dBm. We think this is an issue introduced in this version of Router Utility. It was OK in the version it superseded.
Another issue: In previous versions the user saw the status of each of the WANs which were enabled. In the present version one sees all WANS which could be employed – even if an optional license is required and not installed. We’d strongly prefer the previous functionality be restored. The elimination of this regression would make the product a bit easier to use as information not needed would not be displayed on the relatively small screen.
Feature request: It would be useful if we can see a bit more information in Router Utility vis-a-vis the 4G connection, e.g., RSRP, RSRQ and SINR.
[Edited 01/14/19 to add second issue]
