Surf SoHo MK3 f.w. 7 build 1139
1 WAN, 1 LAN port connected to local PC
Everything works fine, WiFi OK.
I would like to isolate WLAN from LAN, so that WiFi clients can use internet, but not connect to computers on the LAN ports.
Is WLAN hard wired to LAN, or can I assign WLAN to a different sub-net?
Thanks for the help!
Sparky5
Hi Sparky5. See if any of these help you …
I am setting up my new home office and part of that was purchasing the new Soho MK3 Router. Since my office is in my home I am sharing the internet connection with the rest of the home. To prevent others in the house from getting into my work computers I want to create four separate “virtual” networks that can not be seen by each others.
Office Computers/Devices
Home Computers/Devices (Trusted)
Phones/Cameras/TVs/(Non Trusted devices)
Guest (Non Trusted)
I have been reading up on Subnets an…
Please refer to the settings below:
VLAN settings
Defining Guest VLAN & LAN
[image]
Details Guest VLAN setting
[image]
Details LAN setting
[image]
WIFI SSIDs setting
WIFI LAN SSID
[image]
WIFI Guest SSID
[image]
Thank you
Is it possible to totally isolate a WiFi client such that they can see the Internet and nothing else?
In another posting here, user sitloongs was kind enough to help me setup an SSID on its own VLAN. That worked great. But each WiFi user on that VLAN-isolated SSID can see other devices on the same SSID.
Is there a way to prevent that?
By way of comparison, TRENDNET calls it “Wireless Client Isolation”
[image]
TP-LINK calls it “Allow Guests to See Each Other”
[image]
Layer2 Isolation is …
Rick
All excellent articles. Thanks especially to NoName for documenting his setup experience so well. This approach worked fine for me. Router setup is not for the faint of heart. No wonder there is so much router and wifi hacking. And thanks to the Peplink tech support team.
Sparky5
