Better built-in cellular module or no cellular module then select one of choosing? 1gbps throughput instead of 900? WiFi WAN ability?
Nothing has been released as far as a new model of the 20x, It’s just around 2 years old, so I’m not sure that it’s due for a refresh yet.
The newest model would be a br1 pro 5g, with dual core, but it would depend on how many wans, throughput and features your would need to see if it’s a good fit for your use case.
BR1 Pro Cat20 or 5G would be great if it had a usb for usb ethernet/max adapter…
The br1 pro 20g and the br1 pro 5g does not have a usb port.
You would want to look at the 310x or 310 fiber 5g/310 5g.
big jump in price. seems there is a bit of a gap peplink could maybe fix in next hardware refresh?
