Hello and Good Day to All
Is there any way this can be done?
I can’t connect via the utility app with the Surf otg.
Is there? Is there a workaround?
@Ballistic, do you mean you are unable to manage the Surf-On-The-Go via the Router Utility App? If so, then it is not supported as per the description from the product page.
This app requires connectivity to a Peplink Balance, Pepwave MAX or Pepwave Surf SOHO router (running Firmware 5.4.0 or later) and will not work without it.
If I get it wrong, would you mind elaborating more on what you trying to achieve?
Thank You
I understand now.
Have a great day.
