Hi
I use a PEPLINK 710 with 5.3.11 firmware… It seems there is no way to monitor bandwidth utilization with SNMP.
Am I wrong ? I Hope !
Cyril
Hi
Cyril
You should be able to monitor usage by SNMP, Cyril. Is everything setup properly? You can download our Balance MIB at https://secure.peplink.com/support/downloads/
Hi Kurt
When I open the Peplink Web Dashboard, I get the real time upload and download Throughput at the bottom of the page.
I’d like to have the same information with snmp.
I already downloaded and actually use the Peplink Mib. But even if I’m able to retrieve the PEPLINK smnp values, I didn’t find any I can use to get the upload and download bandwidth realtime utilization. What are they ???
Cyril
Thanks Cyril. Real-time bandwidth is not yet available by SNMP. If you are comfortable with CLI then with our latest firmware you can also SSH to Balance and get real-time bandwidth. Any interesting application for real-time upload and download throughput by SNMP?
Kurt
OK I’m gonna upgrade to 5.4.1 tomorrow and try to use the CLI, that can be a solution.
We keep in touch.
Cyril
Thanks Cyril. There are a number of other exciting new features on firmware 5.4 too. Once you are connected to Peplink by SSH, what you are after should be under “get bandwidth”. Have fun!
Hi, i would like to check, is this real time monitoring via snmp available now?
