Hi There,
I have 3 connection on my Peplink Balance and i need to test 1 connection without disconnection the other 2. So can i set 2 or 3 PCs for example to use only this connection and not be connected to the other 2?
Thank you.
Hi There,
Thank you.
Hi joeyazar,
same answer than your other question. Outbound policy is your solution
Regards
Dennis
