Is it possible to change from UDP to TCP for speedfusion hub service as UDP is unreliable and has no flow control?
Have a look at TCP accelerator feature due out in next few weeks https://youtu.be/vaDFrt58lKY.
HCG
Hi thanks for the reply. We are already running this firmware but I see no option to change the speedfusion encap protocol. am i missing something?
8.1.0 build 4948 (beta)
It hidden under a question mark where you set the port number.
Thanks! Of course it was hidden. I should have guessed that. Are there any other easter eggs peplink gave us in this build that you know of?
