I’m trying to understand InControl2. It appears that you must use it to leverage some features - like StarLink control. It also seems as if it might be needed to configure products like AP One AX Lite (is this true??).
My Max BR1 5G is out of warranty and I don’t think I really need to access/config/control devices from the internet. Certainly not if it’s going to cost me a few hundred dollars a year vs applying that $$ to new hardware upgrades…
Can someone shed light on:
Is InControl2 really completely free?
Can I use Peplink devices without it / Will I have missing functionality (like Starlink features)?
Will I be able to completely configure an AP One AX Lite as a repeater with multiple VLANs without InControl2?
If I buy a switch, will I be able to completely control it without InControl2 (admin port on back?)
For the ap ax lite, yes you can use it without a care plan or IC2 on either device. The peplink itself can run an AP controller and manage the ap (up to 30 APs on the br1 pro 5G) if you don’t have/use IC2 to do it.
Also add unlimited connections to fusionhub solo as long as the devices are under PrimeCare.
Network object management.
Ability to mass change admin wan settings/passwords easily.
Upgrade from 2 pepvpn’s to 5 pepvpn’s
peplink dyndns service
Hot failover , wan smoothing which you mentioned.
The switch/router has it’s own web interface so you can still manage it.
Depending on the model and your budget primecare is an excellent value.
Clarification: Are you saying that if a device is a primecare model, presumably all newer devices (?), that the only way to use InControl is with an expensive yearly fee?
Can InControl be ran locally in my own server at home?
@fvfrenzy Currently incontrol2 is part of the primecare subscription and not available separately.
Their is a private incontrol2 model , however it’s not geared for personal use and intended for governments and enterprise installations of hundreds if not thousands of units.
Maybe we can find another solution for you , have you considered pepvpn tunnels to a remote server?
What are your goals , remote access ?
There are several ways to provide this.
Which model are you considering?
