IPsec VPN status in IC
Would it be possible to see IPsec tunnel status on IC?
You can see the connection of each location to the FusionHub
but, the IPsec tunnel from FH to remote location isn’t displayed in IC
I agree it makes sense to me for them to add this.
I totally agree! I have been using Synology routers for several years with ipSec VPN and the Synology allows me to see the status of the ipSec connections I have created. It will show “connecting” or “connected”. But with the Peplink routers it shows me nothing other than the profile added, which is not very helpful at all, I have no idea visually if it is connected! Just the other day I was actually messing around with ipSec trying to setup a connection on my BR1 Mini and I could not tell if it was connected or what it was doing. A visual status feature for VPN connections definitely needs to be added to Peplink routers. I do hope that Peplink sees the need and agrees with us and adds it soon.
