Hi, I need to create 3 different site to site vpn to connect offices with the headquarters.
I’m using a Peplink Balance 710 in headquarters and several Peplink Balance 30.
I was able to create a IPSec VPN Site to Site tunnel but even if I am able to ping Peplink Balance 30 from the headquarters I cannot do the same with PCs behind the Peplink Balance 30
The best place to start is Network>Firewall>Inbound Firewall Rules. Basically you can set the default rule Deny All. Then you can create a Allow rule for the destination network (Source - Network address) and the rest any, then allow. Basically this will just allow the remote network to access your local network while denying all others. Should you have the need to allow others access this can be done by simply defining these in the inbound firewall rules
