I was wondering if there’s a way to configure IPsec tunnels in a redundant/failover fashion on the Balance model routers? What I mean is, set up 2 tunnels where if one fails the router will switch to sending traffic over the second IPsec tunnel configuration.
I’m not referring to the IPsec WAN failover setting as that requires the same tunnel configuration at the other end of the tunnel and I don’t have that option (using AWS site to site vpn which creates 2 tunnels with unique PSKs and IPs).
It seems like this feature currently isn’t available but I thought I’d confirm anyway. In the case I’m correct, and it’s not, is it something that might be added at some point?
Guy
