Hi All,
I’m new on peplink.So i need your help. I got connection problem when i setup ip sec vpn to Fortigate.
So the case is :
1.I set up ipsec vpn, and the i set up apply the nat policies on ip sec vpn profile.
2.The connection already established. But still i cannot test ping connection through other network side
3.But, from vendor network side can do test ping connection to my NAT address
4.I cannot test ping connection from my side to vendor side.
Are there any step that i miss ?Need your help.
Thank you.
Regards,
Robby
