IPSEC VPN [Cisco, maybe others]
I have had a few issues over the years with Peplink IPSEC VPNs, sometimes working, sometimes not - particularly in complex aggressive/dynamic instances where there is no clear reason for the IPSEC tunnel not to establish properly (and with peplinks lack of actual diagnostics for VPN logs…)
Until i came across this; Peplink sends IKEv2 IDs as RFC822/email ID type and not FQDN.
So in an ISO cisco instance - setting as follows seems to fix VPN intermittency/failing to establish for no good known reason.
crypto ikev2 profile BEDSFRPEP-IKEV2-PROFILE
match identity remote email vpn@peplink
identity local email vpn@cisco
If you’re using another vendor maybe specifically setting email type instead of FQDN will also improve things.
Thought id post, incase it helps anyone else.
Holy smokes!
big if true!
I will try this out later today :slight_smile:
