Ipsec vpn between Nordlayer gateway and Peplink Balance
Have you successfully set up an IPSec tunnel between a NordLayer gateway and a Balance 580? If so, could you share the encryption settings for IKEV1 or IKEV2?
Thanks!
Their support site has very detailed docs and procedures. Although they don’t have peplink specific instructions, you can derive them from instructions for a router with a similar setup like a cisco meraki.
There were a lot of references to coordinating setting with their support, or if using the self service options you could specify them yourself.
