Dear All,
we had created an IPSec tunnel (aggressive Mode) between MAX BR1 and Juniper SSG550 , the tunnel is established, but the traffic not going through the tunnel and no ping between both sides, we tried to make the encryption less, then it works good, but if we return the encryption to high, the traffic again will not go through the tunnel.
any advice about this issue?
thanks
