I have two locations and have successfully setup an IPSec tunnel between them. Site A (192.168.1.0) has a Balance 30 and Site B (192.168.2.0) has a Netgear 4 port Giga switch. Site A initiates and Site B is a responder. All is good but I am not able to access servers on site B. At one point I could but I can’t now.
What settings should I be looking at? Do I need to add a static route?
Also, if I use client side software to go through the Balance 30 to connect to Site B, it hangs in Phase 2 even though I have pass through turned on. THis has a separate policy and I can successfully make it work with the Balance out of the way.
