iPhone 11. SSID not found…reset both mk4 soho and phone, changed SSID. Still not working
I can find older iPad
Also usb attach results in unknown device
iOS via USB is not supported.
iPhone SSID should be visible to soho. Assume other devics can see it?
Indeed ML
iPhone will not tether via usb to the Surf soho. But it will via WiFi WAN.
My iPhone is doing this right now
I’ve found that if there are spaces or special characters in the iPhones SSID, the SOHO won’t reliably find the network. Assuming other devices are seeing the hotspot as Martin asked, I would update the network name from ex. “bobs iphone” to “bobsiphone” and do a test.
