i have a challange figuring this out, and maybe anybody here can help me.
i have 2 ipads 4g which needs to connect to a peplink balance 210 on a fixed ipadres over a VPN.
i first wanted to do this over a IPsec because of security, but on this forum i read that is is not yet possile, so instead it is now pptp.
but i have no luck getting this working.
on the ipad i need to fill in description/ server/ account/ password but on the peplink i can only fill in the WAN1 network it is connected to, and the username and password. i figured the username should be the same as the server in the ipad and the account is the same as the external ipadres off the peplink(there is still a router in between so external ip-adress is not the same as the ipadress which is written at WAN1.
what am i doing wrong?
then i have another question: i need the IPADs to connect to the peplink via VPN(ipsec or pptp) and then through to a speedfushionVPN to a PEPWAVE MAX HD2 via VPN (speedfusion or IPsec). i have the VPN to the MAXHD2 working the max hd2 has 2x4g cards so no fixed ip, and therfor i need 2 VPN tunnels connected, is this even possible?
On current firmware we have just added L2TP as well, which would be more secure then PPTP.
IPAD—>PPTP---->Peplink<<<SpeedFusion>>>MAXHD2
As along as you have a SF tunnel setup between the Peplink and MAX device. You can connect remotely to either the Peplink or MAX via L2TP/PPTP and you will have access to the remote location as well.
