IP Passthrough to VLAN going out all WANs
Hi Forum,
I am testing a configuration where I have 8 Starlinks connected to a Balance 2500EC.
6 of the Starlinks are to be Load Balanced (weighted balance or least used) to a LAN client on VLAN 10 (10.10.10.0/24).
1 of the Starlinks (STL7) is to be IP Passthrough via VLAN100 to a LAN client.
From my testing, LAN client for VLAN 100 is receiving the IP address from STL7, although traffic is being load balanced between Starlink 1 and 6, rather than going out Starlink 7.
Is there a way to lock down the LAN client in IP Passthrough to go in/out of STL7 only?
Create a priority outbound policy with the MAC address of the LAN client using IP passthrough as the source and STL7 as the WAN.
That’s exactly what I did a few minutes after posting and it has worked. I had to reboot the router to force existing sessions from the LAN client going out the bonded WANs.
I will monitor and let you know how the solution pans out.
Yep, working very well. TY
