I have put my Peplink Max BR into IP Passthrough via the setting below. Everything seems to be working perfectly except I can not form an L2TP/IPsec tunnel with my router which is directly connected to LAN1 of the Max. Checked the firewall rules on the Max BR and the defaults are all “any any any allow”.
Is it possible the Max BR is blocking the L2TP/IPsec negotiation be some other setting?
If Max BR won’t forward L2TP/IPsec will it allow to form the tunnel to the Max BR and then access my LAN? This raises the question of firewall rules on the internal side of the MAX BR and how to allow my traffic from the tunnel that terminates at the MXBR without allowing a host of bad actors at large, hmm.
Perhaps it is VZW which my only WAN connection for this application.
Thanks in advance.
