I have two MAX BR1 Mini LTEA units. I also will be receiving two SIM cards from Verizon with static IP addresses. These units will be plugged in with an ethernet cable to a single client device.
I want to set up the system so that the two client devices can communicate with each other as if they’re on the same local network. I’ve been reading through the manual and also looking at other topics on the forum to try to figure out how to configure these systems. It seems like I would either need to enable the “IP Forwarding” option in the Cellular WAN, or enable “IP Passthrough” somewhere (not sure where), or possibly set up a NAT between the cellular IP and the private IP.
For NAT, I’ve tried similar settings on other network devices but never got it to work, so I would like to avoid that if possible.
Would setting up “IP Forwarding” get this working the way I want? So from my one device I would be able to ping the other device on the static IP address provided to me by Verizon?
Thanks!
