IP Camera Issue
So I’ve upgraded my business network using a Pepwave SOHO and AP one for broad coverage across the restaurant since we will be switching over to a wireless POS system. The problem I’m having now is that none of my IP cameras will connect via the wireless LAN, work fine on wired LAN. When I hook up a Netgear router, and set up a camera, it works fine. I have no restrictions yet other than WPA2 access so I’m at a loss to understand why they won’t connect. I suppose I could always run another cable to the modem and hook the Netgear back up.
Disclaimer - I have VERY limited knowledge of pepwave routers
Hello @HeyBill,
We would recommend that you get in contact with your local Cerified Peplink Partner here, just select you required region.
https://www.peplink.com/peplink-certified-partners/#AS
IP Cameras can be fickle and it depends on if they have been previously setup to operate with Fix IP or Dynamic IP details.One of the first things you should check is that you are using the same subnet with your new SOHO as what the old Netgear was setup to?
Another thing you may need to check on are the setting for remote access to your cameras and firewall rules.
In some places around the world, you may need to make sure your Peplink Partner is also has the required security licence to work on IP Cameras (as is the case in Australia).
Happy to Help,
Marcus :slight_smile:
