I have a Balance 20. I have two DSL modems with Wifi capability built in on the WAN side of the Balance 20. Wifi is currently disabled on both. Both are also capable of two isolated SSIDs.
On the LAN side of the Balance 20 I have three access points along with my internal network. Two of the access points are capable of multiple SSIDs/VLANs. The third has more basic features capable of one SSID.
I have multiple IoT devices across all three access points. I utilized the VLAN capability on the two access points to isolate and forward to the Balance 20 LAN/VLAN ports. The IoTs on the third access point however are currently uninsolated from the remaining network.
My question is, can the unsecured IoTs be moved to the WAN side of the Balance 20 and connected to one of the Wifi Modems? Is there a better way of accomplishing this isolation?
I apologize if anything is unclear.
Thank you!
