I have used Peplink router utility on my Iphone for a couple years.
I host about 8 devices and all of them sent PUSH notification for my Iphone well.
After migration to new Iphone x with IOS 11.4 I do not recieve any PUSH notifications to me Router utility app.
To resolve this issue i have done fololowing
Checked that all my Balance 210, 310, 580, 380 devices have have “Push event” option is enabled
Checked that in IOS app “Send notifications” options is enabled
Checked that in IOS app all types of “Notification to recieve” are turned on
Checked that IOS allow all Always all types of notifications for Router utility
Re-login to AppStore account and Icloud account
Made hard reboot to the Iphone
Reinstalled app
Right now, Iphone doesn’t get Push for Peplink app, but other applications work well with push.
I’m also having trouble with the iPhone app. The icon shows a number of notifications, but when I open the app it no longer tells me which device generated the problem. I have multiple devices listed. Which one needs attention? The app previously showed which device.
Have you logged into each device which your are on the LAN of each device?
I have found that this feature only works if when you add the device to the app, you are on the LAN of the device.
(Notifications are pushed but unable to remotely access the device via the app)
Just to confirm the issue, are you opening the Notifications drawer and wait for the notification ? I found that the notification is not refreshed. Can you please minimize the apps and reopen the apps and check whether notification will shown on drawers ?
