It sim injector supported in 20x? The UI screen for both the cat4 and cat18 modem show configuration options for “Remote SIM”.
B20X with FlexModule Mini will supports SIM Injector.
I updated the list accordingly. Thank you.
Hi Team,
Hi @TK_Liew,
is a technical drawing with all dimensions is available for the HD1 and HD2 Dome? This should also contain the distance between the holes (with diameters) and preferably a drilling template.
Dennis
That would be awesome. We are looking at recommending domes in-place of other Peplink hardware. Everything marine we install on boats comes with a template, drawings, measurements, sometimes CAD. Very important for installation.
