OK please let us know which it is. Higher power is better in some cases. I’d love to see 26 dBm or above which I think was the MK2 wifi power. Is there any way to set a higher power output via firmware/software setting or is it a hardware limitation?
Looks like the BR1 Pro will be 3x expensive as the max at $1500 us, ouch:
Was hoping this would be a affordable 5G option with finally good routing speed, really like my SOHO with my CAT 20 hotspot and have been wanting to move up to a real router for a while waiting for 5G offerings but thinking I may be getting priced out of Peplink hardware going forward.
EDIT:
After some googling I’ve discovered this excellent article: What is the Difference Between NSA and SA? Which is Better? – Router Switch Blog (router-switch.com)
TL;DR:
**NSA (Non-Standalone) **refers to the joint networking of 5G and 4G LTE, which means that 5G networks are deployed on the basis of existing 4G equipment. SA (Standalone) is the final form of 5G. Infrastructure such as base stations, backhaul links, and core networks are all dedicated to 5G, which can maximize the potential of 5G networks.
For most operators, the difficulty of SA construction and capital investment are the biggest flaws. Therefore, many countries around the world will choose to slowly transition from NSA to SA.
Will the Peplink Devices eventually get StandAlone (SA) support for all of the 5G NR bands? This would be especially useful for the Tmobile 600mhz bands in more rural locations…
I am interested to hear the answer. I have a location that has t-mobile extended range 5g on n71 (600 mhz) available. are you saying that t-mobile is using SA for n7a instead of NSA and peplink is not supporting SA?
I don’t think this is one where you can have “Standalone coverage” or “not standalone coverage”. I think any area that has “StandAlone” enabled will support a client device (router, phone, etc) that can USE “StandAlone”… otherwise all “Non StandAlone” devices will still work…
Yes, we will eventually get StandAlone (SA) support. This depends on the chipset capability and availability. Perhaps we will have some more news in Q3.
