InTouch via FusionHub FAQ
Can I remotely access my device with InTouch via FusionHub?
Yes, the only requirement is that the device and FusionHub require a valid care plan subscription. InTouch can then be accessed through InControl.
What is the throughput limit of InTouch on a FusionHub?
The maximum speed is 10 Mbps.
Is there a way to increase the speed?
No higher speeds are available.
Does FusionHub have a quota that needs to be topped up?
FusionHub does not have a quota. Usage will only be deducted from the remotely accessed device’s SFC quota.
