Hi
I’m using peplink balance one with latest firmware. I managed to configure Vlan’s but unable to restrict Vlan’s from communicating each other, is there any way to configure Inter Vlan routing?
appreciate your help
-Mohan
Hi
-Mohan
In coming firmware, there will be a Inter-VLAN routing option on each VLAN in order to restrict the communication of each VLAN.
Dear Chung Lai Chan
Thanks for your info, When can we expect new firmware?
Thanks and Regards
Mohan
Dear Chung Lai Chan
in the meantime is there any way to restrict access from one vlan to another vlan using the peplink firewall function?
Appreciate your reply
yes, you can add the Inbound and Outbound Firewall Rules to block that subnet each other.
Regarding the firmware 6.1.2, we cannot provide the actual schedule, but should be within a month or more.
Dear Chung Lai Chan
I tried Inbound and outbound policies but doesn’t work…
I created 3 Vlans
Vlan 2 - 192.168.2.0
Vlan 3 - 192.168.3.0
Vlan 4 - 192.168.4.0
now I tried to block Vlan 2 accessing Vlan 3
created inbound and outbound policy but doesn’t work
inbound / outbound
192.168.2.0/24 - 192.168.3.0/24 deny
Please Advise
Thanks and Regards
Mohan
Please try to add the rules in outbound
Outbound
192.168.2.0/24 > 192.168.3.0/24 deny
192.168.3.0/24 > 192.168.2.0/24 deny
Tried but still communicating each other, is there any other settings need to change??
Thanks and Regards
-Mohan
Hi Mohan,
Are there any other firewall rules in place out or inbound beside the
Outbound
possibly there could be another rule above that is allowing the traffic?
Taylor
Hi Mohan,
I had reproduced the environment that similar to your setup. It is working. Can you share how you do the testing?
Dear Taylor
There is no other policy except default policy in inbound. tried by denying inboud policy but still communicating vlan’s each other.
Thanks and Regard
Mohan
Hi
Thanks for your email
i Created 3 Vlan’s
vlan 3 - 192.168.3.0
And Created Outbound rules to block Vlan2 to access Vlan 3.
but still communicating Vlan’s each other
am I missing something here?
Thanks and Regards
Mohan
Hi Mohan,
Understood your setting. I just need to know how you do the testing.
If you do ping test:-
Where you ping from (From PC in Vlan 2)?
Where you ping to (To PC in Vlan 3)?
Are you ping to Peplink LAN IP (Vlan 2 or 3 LAN IP)?
Hi
Hi Mohan,
Try ping to the other IP in the vlan, instead of the Gateway IP itself, it should work.
Thanks and regards,
Wei-Ming
Thanks it’s working but
Thanks a lot for all your suggestions.
Thanks and Regards
-Mohan
