hi, I have balance one core, my tm unifi is 800mbps,
when i speedtest, it only can get 200mbps, please guide me how to get full speed
Hi. Are you saying you are using Wi-Fi as WAN where the Wi-Fi AP is a Ubiquity Unifi device? Kindly clarify.
I am using cable connection to wan1,
TM unifi is local isp
Hi again. As you can see here – https://www.peplink.com/products/pepwave-surf-soho-specs/ – the SOHO’s maximum rated throughput is 150mb/sec.
Hi
My model is balance one core,
Ahhh. Sorry – my error. You were clear about that in your first post. The Balance one is rated for 400 or 600 (depends on the number of WANs – https://www.peplink.com/products/balance-one/ ) – but that does not explain why you are getting 200. So, I’ll defer to others.
can you try connecting directly (remove the peplink device from the mix) and see what speeds you get?
Hi
If I connected via isp router directly, I can get 800mbps which match my subscription speed
hi thyekc
We will possibly need to have a closer look at what is happening. Could you open a support ticket by visiting Peplink Ticketing System and we will see what is happening.
