Hi Team
When I set speedfusion between HD4 (connected to a wan 1 , cellular 1,2,3,4) and a balance(wan 1) where do I go to internet if I’m not routing traffic to the balance?
Hi Team
Hi Arturo,
If you didn’t enable the “Send All Traffic To” option in the SpeedFusion settings page, then the all the Internet traffic will leave the HD4 directly (via WAN 1, Cellular 1, 2, 3 &4, assuming all these are Internet accessible).
The behaviour will be a normal link load balancer, which follow the Outbound rules defined. More information on outbound Load Balancing Algorithms can be found here.
Thanks and regards.
