I am trying to setup a VLAN on one port to allow easy access to reconfigure new devices on their default IP address of 10.90.90.90.
Setup VLAN 10 is configured as follows:
Inter-VLAN is checked for both MainNetwork/VLAN None and Setup/VLAN 10.
An explicit Router Internal Firewall Rule is Enabled for any protocol from 192.168.34.9/24 to 10.90.90.89/8
From the System > Setup tab on the Surf SoHo Mk3 with Firmware 8.3.0, the ping to LAN Setup > 10.90.90.90 is successful.
From a Windows 10 machine on 192.168.34.9/24, with Windows Firewall turned off, pinging 10.90.90.90 is unsuccessful.
What am I missing, or what can I do to troubleshoot?
When devices are configured with a default IP they expect another device on the same subnet to try and access them so they don’t typically have a default gateway set (ie 10.90.90.89 in your example) to allow them to reply to devices in other subnets.
Use virtual network mapping to setup a virtual local subnet you can hit from your management VLAN that maps to the 10.90.90.89 IP (don’t use the /8 its too big. Use /24 instead) eg:
