Currently new setup for our customer using Peplink 1350. Branches all traffic (VPN + Internet) need to go via HQ.
User request the isolate incoming traffics (Speedfusion + Internet). i am using inter-vlan routing to isolate the traffic by vlan at switch. Latest now, have to deploy HA. Will it work ???
Hi Jason,
HA setup & Inter-VLAN routing are two different entity. As long as the standalone/single unit deployment working fine, it won’t cause any issue for the HA deployment.
Possible please share us the network diagram for the deployment & we can advice further.
Thank You
The Branches traffic (VPN + Internet) need to go through HQ then access to internet.
Hi Jason,
The given diagram doesn’t really include the routing info for the internal network & the internet gateway.
Can i assume you going to have internet gateway router for VLAN10 & internal router for VLAN20 (device that doing routing) ? And you need Peplink Balance to route the traffics accordingly ?
For your information, if you want Peplink Balance to route 0.0.0.0/0 to internet gateway, make sure you route it using un-tagged VLAN
Thank You
