I have a Balance One set up with two VLAN networks:
10.0.32.x Untagged (which has inter-VLAN routing ON)
10.0.64.x Guest (which is tagged 1003 and has inter-VLAN routing OFF)
This works like I want: Guests can’t see anything on the main untagged network.
I have a printer which I would like to be visible to both networks. In other words, guests on the guest VLAN would also be able to print.
Is there a way to enable this somehow? Should I move the printer to the Guest network? Or use a static route? Or perhaps Bonjour forwarding?
