We have a fusion hub in the office that the HD4 boxes connect to. We use pepvpn on them. When connected i lose them in the Incontrol site, so i cant edit them from HQ.
Is it posible to make an update where you can say, LAN port 1 where we have an IP that is forwarded from the SAT to the box, that it can connect around the pepvpn and let us have access?
Or is it posible to have it connect throug the VPN to the office and then to the Incontrol?
Fusion hub is located behind a Cisco firewall and a Cisco switch.
We need this sins we uses tech as Riverbed and Allot that we need the connection routed throug so we can optimise and limit users access to programs etc.
I discovered this issue some time ago. I have a B710 on central office that the default outbound policy is not having internet. So I added an outbound rule that say:
Destination: peplink.com
protocol udp 5246
alg: priority with all internet.
With this two rules, I can get the notification for router utility and IC2 stats for the central device.
But, when I depoyed remote units, I wrote an outbound rule to send everything to central unit by SF. I discovered that those rules wasnt being followed and the remote unit couldnt send notification nor IC2.
What I did was in every remote unit wrote this rules, but I think this is a bug, because remote unit traffic should go out to peplink.com because the source is ALL.
