Hello support team,
how are you?
Recently, I saw on the website that Peplink Balance 20 has a throughput of 100 mbps.
This is a new release of hardware or is a new firmware that enables this value of throughput?
Hello support team,
how are you?
Hello Bruno,
The Peplink Balance 20 did indeed have a hardware revision as well as Firmware optimization that brought its throughput rating to 100mb. Basically, it was a bit of both that did it.
I do hope this helps to clarify matters, please let us know if you have further questions at all.
Best Regards,
Jason
The Peplink Team
Thanks for the answer,
Can you tell me what build the throughput of 100 Mbps is available?
Try the 5.2.2 or 5.3.8, both should have a faster throughput.
